My XR400 Rebuild
So this is the third time that I tried to post this and so we'll see if it actually posts! I bought a 2000 XR400 in December and have been rebuilding it since then. I initially tore it down to the bare frame and then just started cleaning or replacing parts as necessary.
I thnk its the pictures that have been causing problems so i'll try those again later.
I didn't run into many major problems except for the typical swingarm bolt problem. I ended up cutting the bolt off and replacing the swingarm with an extra one I received with the bike. I took the engine into a machine shop to have the remainder of the bolt drilled out properly.
I broke the engine apart just enough to replace the cam chain and then put the original piston and rings back in. I figure I could tear it apart later if need be.
The carburetor seemed to be in decent shape but i decided since I had it out I would get an overhaul kit and replace the seals etc.
I was finally able to get it all back together and after running it down the street a few times I got it to roar to life.
Now I've got to get it running smoothly and properly and thats where I need some help. I've never tuned in a bike before so I don't really know a lot about it.
1. I put a UNI air filter in and so I think that I need to rejet the carb. It runs well enough at low RPMs but when I open it up going down the road (even when done slowly) it starts coughing and kind of sputtering.
2. It smokes like HELL!! Sometimes its not too bad but when I really start revving the engine I get a nice large white cloud forming behind me. I did not do any work to the cylinder or valves as they looked ok. I was unable to measure the cylinder because i do not have the tools for that. I am guessing that some new rings would be in order.
On the way home
Ready to begin
Changing the cam chain
Frame cleaned, painted and reassembly started
I have a bunch more pictures but most were simply for my reference when I put it back together.
Had to leave it here for a while because work was taking up too much of my time
When it first started to run!
Just missing the trim pieces and various guards.
When talking about jetting, you always need to give your elevation. When you had the carb apart for cleaning and the new seal kit, did you take note of the jet sizes? Did you check/set the float level? Needle clip position? You need to find out all of that.
You should check the valve clearances.
I too think it probably needs new rings, at the very least. If just blows smoke for a few minutes after starting, it's most likely the valve stem seals/guides. If all the time, rings or more. Pay attention to your oil level, don't let it get too low.
The exhaust looks stock. Look inside the exhaust exit, between the silver trim ring and outlet pipe. Do you see and holes? If so, it has had the Gordon mod done to it.
Is the underseat snorkle for the airbox installed?
Once you do all this and figure all this out, then we can talk jetting.
Thanks for the help Trailryder. I'm tired for tonight but I'll try to post those details in the next day or two.
Did it smoke before disassembly?
Is the oil over-filled? There is a special procedure for these dry sump bikes.
Did you orient the rings exactly as they were before disassembly?
If you replace the rings, you must hone the cylinder.
TrailRyder, here is the information you asked for. DFW area seems to be around 500-1000 feet elevation and the local riding probably no more than 3000 feet. I believe the installed jets are 142/52. The float level was checked and was within spec. I cannot remember the needle clip position but it matched the replacement one which was in the center position (3rd from end)
I adjusted the valve clearances before running the bike and they all seemed a bit tight (even after rotating the engine 180 degrees) so there were adjusted within the limits specified in the manual.
The snorkel has not been removed but the previous owner drilled holes in the airbox cover. The exhaust doesn't have any of the Gordon mod holes drilled in it.
I would like to buy your untouched-unmodified silencer if you decide to get one of those sexy pretty ones.
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
