SHOWA A-KIT STACKS NEEDED.
Does anyone have info on the stacks inside their Akit stuff.
I have read threads etc but seems very long winded reading through. surely someone has had suspension valved by top tuners, 3 companies and looked at what they got.
I have 2008 style A-kit from 2010 CRF. BUT ONLY EVER FIND STACKS ON HERE FOR OEM STUFF.
Any info guys.
i would have thought every a-kit will be valved specifically for the rider they were intended for, so each setup induvidual. you could start with a baseline and work from there?
It is currently set for supercross AMA PRO RIDER.
JUST LOOKING FOR SOMEONE TO GIVE ME A GOOD OUTDOOR BASELINE.
180lb 22 year old local amature intermediate to expert level.
Front springs now .47 rear 5.4
Do you have it apart already? Post whats in it most will chime in so you can adjust it. Note it will probally always be a tad harsher in square edge and smaller chop because those tubes are much larger diameter.. Unless your fast and heavier than you say..
CURRENT STACKS ARE AS FOLLOWS
FORKS
OEM PC SX
Springs: .49kg
PS Springs: OEM
Oil Height: 400cc
Comp: 12
Reb: 8
Spring Seats: SX Seats
BaseValve: PC
Count O.D. Thickness
9 30 x 0.15
2 29 x 0.15
1 28 x 0.15
1 26 x 0.15
1 25 x 0.15
1 24 x 0.15
1 23 x 0.15
1 22 x 0.20
LSV:
1 16 x 0.15
1 15 x 0.15
1 14 x 0.15
1 13 x 0.15
1 12 x 0.15
1 11 x 0.20
MV:
7 22 x 0.15
2 20 x 0.15
1 18 x 0.15
1 16 x 0.15
1 14 x 0.15
4 12 x 0.15
Collar 2.85
Float = 0.5
Rebound:
3 21 x 0.10
1 19 x 0.10
1 13 x 0.10
1 17 x 0.10
1 15 x 0.10
1 13 x 0.10
1 11 x 0.10
1 10 x 0.10
1 9 x 0.10
SHOCK
Shock PC SX
Spring: 5.4kg
Sag: ?
Nitro: 150psi
Oil:
HSC:
Comp:
Reb:
Comp PC
12 44 x 0.20
1 30 x 0.15
1 42 x 0.20
2 40 x 0.25
1 38 x 0.30
1 36 x 0.30
1 34 x 0.30
1 32 x 0.30
1 30 x 0.30
1 26 x 0.25
1 25 x 0.25
1 24 x 0.25
1 23 x 0.25
1 22 x 0.30
Reb PC
6 40 x 0.20
1 30 x 0.12 x-over
1 40 x 0.30
1 38 x 0.30
1 36 x 0.30
1 34 x 0.30
1 32 x 0.30
1 30 x 0.30
1 28 x 0.30
1 26 x 0.30
1 25 x 0.30
Wow those are some gnarly stacks, im sure a few others will chime in but itll be much softer if you reduce shim thickness overall instead of a .15 use a .10...
The BV will be the same as any 47mm fork.. Something like
30x.10 (15)
29x.10
28x.10
27x.10
26x.10
25x.10
24x.10
22x.10
20x.10
18x.10
16.25
"low speed valve"
16x.10 (10)
15x.10
14x.10
13x.10
12x.10
11x.20
Then the MSV will be basically the same too but with a slightly larger o.d. this is what most showa kit forks come with.
22x.1 3
19x.1
17x.1 3
(9mm od shim under 6 id 8 od 2mm length slide collar).30 float.
The Showa kit forks for outdoor usually have a spring tube (which Pro Circuit basically made a copy of to sell) The SX perches will be too restrictive for MX so you will unfortunately have to buy some spring tubes (and run the oil height 350cc) If you can't afford/find some spring tubes..you can drill/mill out the sx spring perches and run a lower oil height..say 360-370. It will still be pretty harsh.. so you might want to increase float some as another band aid fix.
Forgot to mention too.. If you are running 2008 intended forks on a 2010 you are going to have to compensate for the longer travel (about 20mm if I remember correctly) You can run the forks much higher in the clamps but be prepared for your front wheel to slam the fender.
  • Similar Content
    • By Wade Beall
      I’m looking for stock rear suspension link. I bought my 2007 xr650l with a lowering link on it and I want to go back to stock height.
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Alex Wren
      I recently bought 1988 xr200r forks to go on my 2002 xr200r (got them revalved for my weight and riding style), and I only bought the fork tubes. As I was trying to put them on l, I realized that they do not fit in the triple clamps of the ‘02 xr. What do I do? Please help!
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
