83 XL600R Coil/Plug issue
On my 83 XL600R I've noticed that the spark plug cap doesnt "snap" onto the spark plug. I thought maybe the spark plug cap was designed for a full size spark plug terminal instead of the small threaded one, so i tried a regular plug, and the cap wont fit on at all. Seems like the cap(coil end) is either extremely worn out somehow, or its designed for some specialty spark plug that ive never seen before.
I'm guessing i should replace the cap, but with what? Can i just do a new wire/cap? Or do I have to replace the whole coil?
Without pushing it onto the plug myself I couldn't tell you if it fit properly or not. But it's probably the original one and I could see it getting a bit loose if it's been pulled off a thousand times over the years. If you want to replace it you can just get the cap from Honda.
You should be able to feel the it slide over the threads on the spark plug. Almost sound like cinching up a nylon cable tie.
You could just replace the cap if you're lucky enough to live somewhere that still has/sells them, I know in NZ they're not sold at auto shops ,,least I never see them. Gone all modern down here and you seem to need to buy the cap which is already fixed to a cable and isn't able to be seperated. Maybe a small engine (mower,,chainsaw) shop may have them..otherwise she's a whole new coil..
It's a bit like the joiners you used to be able to buy to extend such cables..they don't want you being a tight wad anymore so stopped making them sort of forcing you to buy a whole new coil/cable or use a double ended sharpened screw as the joiner..not ideal that,,the old joiners were a fully enclosed job that you screwed the cable into and sealed the ends with gunk..
Edited by Horri
Any ideas on where i can get a coil? Can i use any coil, or does it have to be specific to this bike?
I did the leg work for you and found one in Tennessee. La Follette Honda has one in La Follette, TN. (423-562-5239) They are asking $53.27 plus shipping.
COIL, IGNITION
30510-GR2-405
COIL, IGNITION
30510-GR2-405
Awesome, thanks for the help!
  • Similar Content
    • By Jeremy Evans
      I just bought a 2012 xr650l and it starts and runs great until about 4000 rpm give or take (I’m guessing) it feels like it spits and pukes. Also when releasing the throttle the exhaust pops and hiccups. I am calling the dealership to ask if they are willing to fix the problem as I just purchased from them yesterday but I am curious as to what the problem could be in case they do not offer to help for my “as is” purchase. I have read a couple other topics on here that talk about the vacuum lines being hooked up to an air cut diaphram but I don’t know what that is. The smog delete has been done on this bike as well as a slip on dg exhaust and the side cover has a bunch of holes drilled in it exposing the air filter. The battery has also been relocated. My question is what jetting should I have at 2000 feet? I am planning on opening up the carb to see what the idle jet and main jet are and if they were even changed from stock. Also if someone knows about the air cut being hooked up to vacuum and can supply pictures that would be very helpful. I know that the smog block off kits just plug the vacuum holes and the air cut usually gets disconnected. Thanks.
    • By Chowell
      Cargo rack for Honda XR650l.
      New condition. No scratches or damage. New $199
      See manufacturers website for detail.
      https://cycleracks.com/ProductDetail/tabid/87/ProductID/1/Default.aspx
    • By Pcolamotorhead
      engine parts and misc. parts. Airbox, Electronics, Brake parts.
    • By Pcolamotorhead
      Parting out almost an entire bike. Frame is gone, CDI box, and Wheels, Gas Tank, Headlight & Front number plate. Complete unassembled engine with 9611 miles on it. 90 pounds of compression at cranking speed. According to hondaprokevin.com this is what it should have.  Checked the compression with 3 different gauges.   Valve clearance is good which indicates no cam or rocker arm wear. Oil did not look too bad that came out of it. Corbin seat, Big tube header pipe with Super trap muffler, and just about all the other parts.  Shoot me a message with what you are looking for and I will be happy to take pics and send them to you along with a price. All items are buyer pays the shipping.  Also have some 1996 Honda XR600R parts. Engine cases, Electronics, Etc.  $850 for the motor and you pay shipping, Starter motor not included.
