YZ295 Hard Start/ Tough kick.
Hello I have a 05 YZ295 with very little time one it. The bikes in perfect mechanical shape, I put in a brand new crankshaft, crank bearings, crank seals as well as piston/top end kit. This has the Mo Betta porting with pump gas. This thing has a TON of compression, and is a bear to kick especially when cold. I have a fresh rebuilt 06 YZ478 and can start and kick that thing easily, starts up fine. I can kick 450's over cold or hot even on a hot stall with no problem. I used to play football and still workout, and can leg press a good bit of weight. So i'm kicking with a strong kick but its still tough to get started. Takes a hell of a kick especially when cold. Luckily I live at the top of a 200 foot hill, so I usually just run it down the hill to start it. Is this a common trait of the 295 big bore? I couldn't imagine the high compression race gas head.
Previously to this I had a 265 done by eric gorr and could start it pretty easily. Still tougher then a stock YZ250 to start and kick , but manageable. Started really easy when hot. Do other people have this issue with the 295? Cleaned the carb and verified its still stock jetting 178 main 50 pilot upgraded N3EW needle 2nd clip. Vforce3 Reeds. I ride in harrisburg PA, at sea level, anywhere from 60-100 degrees F. The rebuild didn't help or change anything with the starting issue. Runs great, power everywhere with a ton of mid and low, no sputter or hesitation anywhere. If its a pretty normal trait of the 295 I'm fine with it because I love the power. Just wanted to see if others had this same starting issue when upgrading to the 295? When you upgraded to the 295 from the 250 did the kicking strength go up as well? Was it tougher to start? Also what are others running for jetting at sea level?
I did some searching and theres not much info on 295 jetting compared to stock YZ250 jetting.
Thanks
Ryan
I just installed my EG295 low/mid top end last week and rode it this weekend. It is noticeably harder to kick. It's starts first kick, no problem, but I do have to give it a healthy kick. I'm about at the same altitude/temp as you, how clean does your jetting feel? I'm still trying to dial mine in.
Mine was really hard at first but within just a very few hours it was much easier. I also put a 4 stroke kicker on it,slightly longer but very little,best part it moves the kicker out slightly for a better angle,when i was having problems with mine it had super high compression and my foot slipped off and the peg got me good,had a big knot on my shin for about 3 months.
Good info on the 4 stroke kick starter. I will definately look into that if this doesn't get any better. The jetting feels OK, no hesitation or flat spots, and no pinging, but is tricky to start. I do want to do some plug chops and swap some brass to see if I'm missing anything. Really has no powerband, smooth bottom to top with no "hit", I'm really impressed with that. Air screw at 1 1/2 turns out currently.
It could just need some good break in time. I only have an hour on it now. Every other big bore I've done had some extra kick effort required, but this is more effort then those including a YZ85 112 super mini, YZ250F 290cc YZ450 478cc YZ250 265cc and now 295. This is a large big bore though 45 ccs extra, could have part to do with it. I'm re-valving a set of 07 YZ forks and shocks for woods riding, and will swap it over. It has really great MX suspension done my Axis on it now, its amazing for MX but Terrible in the woods, which is all I do with this bike.
Just remember there are 2 out put kicker shaft sizes,i built a 01 or 2 engine for my 04 which had a 4 stroke kicker,when i built the older engine first thing i noticed was how the 2 stroke kicker sucked,bought a 01 yz 426 for parts and used that kicker,instant help with that 295 motor. Maybe 03 or so up has a smaller out put shaft so just confirm size before a purchase.
The 4ts have a automatic decompression lever on the exh camshaft that drops the compression to 115psi below idle rpm. That's why they are easy to kick over.
It should be about 12% harder to kick over from the change in bore size alone
assume 200 PSI compression on the YZ
250 piston has 5.62in2 =1124lbs at the rod
295 piston has 6.31in2 = 1262lbs at teh rod
Just put a 185 main and a 55 pilot. Throttle response much better off idle,sounds like its a tad fat at idle but can live with that if it stops the surging on chopping off throttle. Enduro next week so that will be the next real test.this thing just likes more fuel.
I'm going to try a JD blue needle and a 50 pilot to see if it cures my surging issue.
Just running stock needle in middle position,had a 48 and went to the 55, nice low speed improvement. Have a 8 slide and rb design carb bore and blade installed also.
  • Similar Content
    • By 216AP
      I recently have been wanting to put a led light bar on my yz125 for night riding. I've looked everywhere for wiring diagrams and can't seem to find anything that makes sense to me. I purchased a 45watt stator from electrexworld and I have installed it but I can't figure out how to hook my light bar to it. There are two yellow wires that come out of the plug and I don't know what to do with them. Can anyone help me or provide me with a wiring diagram? PLEASE!
    • By MathiasJK
      Hi guys, I'm new here and bought a have 2001 a month ago and the engine is almost down in pieces, need the flywheel puller that's ordered and the parts needed for the rebound of the engine. I'm also ordering Haynes YZ manual as I think it will be a good buy for me.
      Anyway, the VIN strarts with CE08CE I think... on the back of my cylinder there where some mechanic had written with a marker pen -01 125. It seems like there have been a major failure before, as the head has small dents in it, and the cases are clearly not the same as the one with the VIN is much much smoother in the inlet and crank case.
      Engine VIN is E111E I think, or something very similar to that.
      It has a white Airbox and floating front brake, I've read on other threads here that that was a new thing for -01, is it?
      Fast help would be much appreciated so that I can order parts as soon as possible.
      BTW, here a rebuild with wiseco crank, all seals, new main bearings, new ring and all new  gaskets cost about 500$. Just the crank at Yamaha was 1,200$ at the local Yamaha centre so you all should count yourself as very lucky!
      Thanks for help! I'll post other threads soon as I'm at the beginning is going to post the cases for a smoother flow and have complete HGS system. I really would love to have a 144 but I guess that will cost me insane money as everything is more expensive here, and I also guess sending head n cylinder to the U.S. would cost way to much too... So I'll, be doing what I can on my own and that's the cases for better flow and matchporting it to the cylinder.
      I much appreciate any help! Thanks!
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Allooushh
      Please help! I recently bought a Yz250f and have not been able to start it, it Has spark, but there are many issues with the carby which I wanna rule out before I leap into a rebuild, ( I want to avoid a rebuild if possible as I’m low on cash). The carby at the moment is a complete mess so the usual steps to fixing it might not work. So here’s the deal with the carb:
      - It’s leaking fuel from overflow ( really fast! ) and when I mean really fast, I mean it emptied my fuel tank in 2 mins.
      - It has a slow leak coming from somewhere under the float bowl
      - the air fuel screw is not adjusted correctly
      - I don’t know if the electrics work on it either
      - I don’t even know if it’s shooting fuel into the cylinder or not, as after kicking it a couple times and it’s not starting I remove the spark plug and it’s still dry. ( I tried putting fuel directly into cylinder from the spark plug hole but the bike still wouldn’t start)
      okay so I know it’s a lot but I’m not expecting anyone to answer every single question themselves. If each person could tackle whatever problem they know it would help heaps. Also just want to know what Order to fix things in as I can’t do air fuel until the bike is running and it won’t run unless I stop the leaking and get it to spray fuel into the cylinder. And buying a new carby is not an option ( I’ve got $40 to my name atm). Please help guys thanks.
