rm250 clutch problem
hows it going. i just bought a 1996 rm250. when i first warm it up and i go to pull in the clutch and shift into gear it stalls. its almost like i shift into gear without pulling the clutch in. after it is warmed up it works as it should. what do i need? a clutch basket or pressure plates or a clutch kit? some help would be good thanks
i tried that but its almost like its the pressure plates that need to warm up to work right
What oil are you using? If your using a heavy oil... the bike will need to be warmed up to thin the oil enough to coat everything and allow them to spin freely.
