2007 crf250r popping back fire on acceleration
Ok guys I recently got a 07250r it has all stock jets and carb has been cleaned multiple times it constantly back fires well revving I've been told its to lean but I pull the plug and its wet put my finger in exhaust and its black I've tried everything bigger /smaller jets timing not sucking air from anywhere starts and runs as soon as u touch throttle it back fires its ass off any help please thanks
Not too lean. Just stop reving it and the popping will no longer be an issue.
You have a race bike, probably with an open muffler that has worn out packing. Not a trail bike with a massive muffler.
strong spark weak spark strong spark weak spark strong spark weak spark, i think your hearing unburt fuel igniting after it builds up from missfires
Edited by goosey
Have you ever
- checked the valve clearances
- re packed the silencer
- done a leak down test on the head
- clean all the wire harness connections, including the main ground wire
- cut back 3/8 off the plug lead and re-attach the cap
- tried a new plug
Edited by Krannie
