Flywheel mounting
Hey guys,
since we dont have suppliers for flywheels in Germany and my friends work for several CNC companies we want to machine some flywheels by our own.
The big question is:
How to mount the weight securely to the OEM flywheel?
Can anyone explain or (would be perfect) show some pics of the mounting mechanism?
Thank you very much
Someone else also wanted to do this - make their own flywheels, although they posted in the ENGINEERING & TECHNOLOGY sub forum. There's so much involved in correctly constructing a flywheel with the tapered center made of a different grade of steel, properly hardened, securely fastening a curved magnet (where do you get those???) to the outer shell which is usually riveted to the center. After a dialog pointing out the details that HAD TO be perfect, I believe they thought better of the project. Not that you CAN'T do it. Just be aware going in there's a lot to it that the manufacturers worked out decades ago.
Oh. OK, that's a little easier. How about buying one off of ebay and copying it. (Is that legal? Probably OK if you're not selling quantities of them.) You'd have a little money into it but you'd certainly have the dimensions settled. Many ebay sellers ship world-wide. As for changing weight of a particular flywheel, the farther from the center, the more a specific weight provides inertia so it will be more effective. Some bikes have a problem with space with the side cover being very close. Sometimes, they sell a thick gasket or a spacer to get some clearance back. I think you could do it!
I see your point and I already thought about various mounting options.
My friends and I are kinda technical freaks. We mounted a CRF steering damper on my YZ frame, machine suspension parts and so on.
I just wanted to know how the stealty or similar flywheel weights are mounted to the existing flywheel.
For reasons of true run I think the best way will be to mount it on the crankshaft assembly and not on the flywheel itself.
Edited by Vietze
Keep in mind there's not much crank shaft available to do anything with although some FWW's do sneak it behind the nut. I'd study some photos of the FWW for the bike you want to make it for. Again, Steahly has been thru the R&D and if they mount a certain one a certain way, that's probably the best way (or the only way) to do it.
I'm just making it now. But, it's not only for the flywheel. The primary purpose is accurate fixation of the magnet for a like E-Line lighting coil.
E-line magnet or any additional flywheel weits make the decentration of mass and shape. It's not acceptable for me,
Hey,
very interessting.
Could you please go into detail a bit more. Its my first time messing with flywheel weights.
The left one on your pic looks like the OEM with additional weight. What about the right one?
Decentration means that the weight is moved more to the left side affecting the handling of the bike?!
EDIT:
Do I see it right that the right one is your modded version and you use a different nut to fixate it to the crank?
You removed the stock weight and machined a different one?
Have you clenched it like stock or have you used bolts?
Edited by Vietze
Yes. I lathed outside of OEM to make accurate circularity and measurement. And I made weight ring with gun metal.
The inner diameter of weight ring is lathed to -0.05mm for the outer diameter of processed OEM flywheel.
They are fixed by shrinkage fit and epoxy.
Decentration,,, Sorry, because my specialty is medicine chemistry, I don't have enough knowledge about engineering technical term in English.
That I want to mean is the offset of balance on rotator.
All addional weight are fixed without enough consideration of rotation center. It makes unfavorable vibration and reduce the durability of the bearing.
If you set a dial gauge to addional weight and rotate the crank, the needle of the gauge will make you have dizziness. :)
It may be a trifling problem practically. However, I can not think, it is appropriate to attach such a thing to the crank that adjusted with 3/1000mm precision.
And more, about E-Line lighting coils, it somtimes comes a more serious problem.
The offseted magnet conflicts with core of coil and harms it. It is based on my own experience.
The right one is the magnet for E-Line like lighting coil. It made from a magnet for Ducatti and brass.
They are fixed with epoxy too. And it processed to fit to the flywheel with 0.05mm clearance and they are fix by special nut that you can see at 1st picture.
Of course the magnet is not the element which is necessary as the flywheel weight.
Too much angular momentum affect to the handling as you know. I'll adjust it optimally with riding. It is easy to reduce mass.
My primary purpose is make up this one. It's under construction.
But, if you think about this concentric issue, you may not avoid some processing of OEM flywheel.
Edited by kmtr
I have a spare flywheel for my bike. We will see what we can do!
Thanks a lot mate, helped a lot!
http://www.steahlyoffroad.com/skin/frontend/default/steahly/PDF/YZ-250-02-10-flywheel-weight-installation-instructions.pdf
The center threads onto the crank and 4 set screws hold onto the flywheel.
  • Similar Content
    • By Lone Danger
      Ok so I'm looking for opinions from those who have been on yz125s and 150 exc/xcw's and maybe the ktm 200's exc/xcw's. You gotta be out there.
      Here's the deal...I'm 5'7" 165lbs. A couple years back I was looking for a small bike for my wife to learn on and for me to play around with and race. Could only afford one bike. I got a '09 ktm 105 sx. Once I got it sprung for my weight it was great. I have been top five consistently in my local harescrambles B class, believe it or not. Ya, you were not the only ones shocked. And did pretty good in the local mx races as well, junior class up here in Canada. Lack of power was sometimes an issue but I learned to deal with it and just scream, scream, scream!
      However my wife is a complete beginner and she is scared of it. I have since moved her to a 4 stroke.
      Just got a mint '01 yz15 mid summer. Like less than 200 hrs! I have absolutely loved it on the mx track. Suspension is perfect and I love the extra power. I had planned to set it up for woods/mx with a suspension revalve. However, did a harescramble race a month ago that was really technical. Granted I have not done anything to the suspension minus clickers, had too much psi in the tires (13 front and 15 rear) (yes I know that's wonkey, I only had time to get a heavy duty tube in the front and had a stock tube in back. Less psi in the back would have been instant pinch flat because its so rocky) and it was running rich. I had to scream the thing to keep it running and even changed a plug mid race. Well I'm sure you can guess but it was the worst experience I have ever had on a motorcycle. The more open sections I passed a lot of people but the tech sections required way more effort than I liked and the suspension beat the hell out of me!!! Like my knees, wrists, and shoulders were just done. (I was out there for three hours).
      So keep in mind that I just came off a 105sx with suspension mods (set up for woods/mx). I have no problem slipping clutch and shifting precisely, yatta yatta. (I don't think the 105 would have done well here either due to even less power, however...) I've been second guessing fixing this 125 up for woods ever since I rode a friends '09 ktm 250xcw. I rode it on a local mx track. The power was just so effortless and I was absolutely floored by how the suspension worked. I never thought that I could hit the woops that hard and clear every jump on the track on an xcw and feel THAT good! It felt a lot heavier though, and I think the price tag on these things are going to be a stretch.
      So here's my question. I want the lightness of a 125, but want to be able to race both woods and mx. How does a 150 exc/xcw ENGINE compare to an mx 125 engine? I love the 125 engine, but more low end would be usefull in tech areas. But if there is not a huge difference, I will probably just revalve the yz for woods and go tubless, etc. The 150exc's are so expensive and I hardly ever even see one for sale unless its brand new. I don't want the weight of a 200/250/300. I barely touch the ground on a 125....so it has to at least be light. Is it worth waiting for a 150 engine? Thanks guys.
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
