Carb swap info
So I got a FCR 39 from an 03 400E that I'm going to put on my S. Is there anything I should do to it/check before I put it on or just leave it stock?
You should make sure it has the correct jetting, other then that, im not sure, i do not have one of those FCR 39'S.
yet. :D
Jetting seems straight forward. But then there is the o-ring mod, the AP mod, and the coast enricher mod. Are these needed? And is there and parts that need cleaned or replaced as regular maintenance?
O ring mod is not applicable for the E model Fcr....The "Eddie mod" is....
With 3x3, near sea level..check the carb has these settings.....
160 main jet..... (not stock)
200 main air jet (stock)
60 pilot air jet ..(stock)
EMN needle clip 3 or or JD Blue needle clip 4 or stock DXP needle clip 5 (in order of preference)
45 pilot jet..(stock)
2.25 turns fuel screw
Optional ,but recommended ,are the following..
1) Remove Coast enrichener ...Join the ports on the carb with a left over piece of hose and cap the port on the head..http://www.thumperta...29#entry9885029
2)Do the Eddie Mod....http://www.thumperta...light=eddie mod
3)To make easier pilot circuit tuning I recommend u get a R&D Flex Jet remote fuel screw...
You will need to slightly enlarge the fuel screw orifice on the bowl.,(with a drill) to install the Flex Jet...http://shop.thumpert...w-p4172471.html
Awesome Craigo, thanks for the info! I've been digging for a couple hours now and it's confusing with the different carbs and kits and mods out there.
Can't wait to get this puppy on!
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
