XR650L hot cams fuel economy / jetting
I have a 02 xr650L that I just always rode in the woods till now. The previous owner put a hot cam and Q4 fmf exhaust on it. It has stock gearing 15/45. It runs great, starts in the cold, idles well, no throttle bog. But looks rich by the soot on the muffler outlet and black rear fender. I rode it out to get the title transferred yesterday since I’m putting in on the road to commute to work for the summer. First real “big” trip. About 50 miles there and 50 miles back. I ran 65-75 and pushed it up to 85 a couple times. Got about 35mpg. Is that average for a modified bike at those speeds? Seemed a bit low to me. I was hoping some people with similar mods could chime in. thanks.
Mine gets around 35 offroad with Hotcam Wiseco 9-1 piston, Delortto pumper, Supertrapp/10 discs K&N and 15/49 sprockets. Might be it is too rich if you're only getting 35 onroad.
I would suggest that you give it a good ride - stop the engine quickly and remove the spark plug (you may have to wait a while to let it cool down unless you have heat resistant hands - that will tell you exactly how the engine is running. The following link may help http://www.dansmc.com/spark_plugs/spark_plugs_catalog.html
Mine gets about 35 mpg with a stock engine, but opened airbox, jetting and a pipe.
All of the bikes I've owned recently get about 35 mpg for most riding. The Ducati ST2 could hit 50 on a long trip, but all other riding was 35. I think my KTM is more like 32.
I ride for run rather than fuel economy, so I just accept it.
My 94L gets 40-42.....I have a Hot cam stage 1, bored 3 times with high comp piston 10.5 I think, "STOCK CARB" FMF power bomb and super trap -4" Gears are 16/39 highway and 16/45 dirt
Jets are 58/175 but going to go to 180...Rode with two other 650L's and two R's and they were the same as mine and all burnt the same amount of oil, that was on a 600mile trip in Baja, mainly on the tierra.. My bike is also not for show --I ride hard..only drowned it three times crossing flooded areas,
ya yours could do better, I run 91 octain or better
oooops it was a 15 front sprocket
14/48.........Megacycle Cam,,11.25-1 JE, FCR MX and fifth overdrive and alot of other mods.......mixture of 60% or better offroad 40% on.........i get 50-55 mpg.........ThumpNRED gets about the same with the FCR MX.......i`m a little rich i think.....
Even with the stock carb i never had that low......most people jet these way too rich to keep engine temps down....with the CV carb i had to go down to 52/155 to get the plug a decent color......
B
  • Similar Content
    • By Motorius
      Can anyone tell me if a Showa rear shock off an XR650R would definitely fit an XR650L (mine is a 2008)?
      Thanks!
    • By Pcolamotorhead
      Parting out almost an entire bike. Frame is gone, CDI box, and Wheels, Gas Tank, Headlight & Front number plate. Complete unassembled engine with 9611 miles on it. 90 pounds of compression at cranking speed. According to hondaprokevin.com this is what it should have.  Checked the compression with 3 different gauges.   Valve clearance is good which indicates no cam or rocker arm wear. Oil did not look too bad that came out of it. Corbin seat, Super trap muffler, and just about all the other parts.  Shoot me a message with what you are looking for and I will be happy to take pics and send them to you along with a price. All items are buyer pays the shipping.  Also have some 1996 Honda XR600R parts. Engine cases, Electronics, Etc.  $850 for the motor and you pay shipping, Starter motor not included.
    • By Jeremy Evans
      I just bought a 2012 xr650l and it starts and runs great until about 4000 rpm give or take (I’m guessing) it feels like it spits and pukes. Also when releasing the throttle the exhaust pops and hiccups. I am calling the dealership to ask if they are willing to fix the problem as I just purchased from them yesterday but I am curious as to what the problem could be in case they do not offer to help for my “as is” purchase. I have read a couple other topics on here that talk about the vacuum lines being hooked up to an air cut diaphram but I don’t know what that is. The smog delete has been done on this bike as well as a slip on dg exhaust and the side cover has a bunch of holes drilled in it exposing the air filter. The battery has also been relocated. My question is what jetting should I have at 2000 feet? I am planning on opening up the carb to see what the idle jet and main jet are and if they were even changed from stock. Also if someone knows about the air cut being hooked up to vacuum and can supply pictures that would be very helpful. I know that the smog block off kits just plug the vacuum holes and the air cut usually gets disconnected. Thanks.
