Rm 250 bottom end
I recently bought a 02 rm 250 that was blow up, put a top end it it and figured out it need a new flywheel ad stator, put those in, then it fired up but it was making weird noises ad the flywheel was going up and down and causing those metal shavings I was talking about. So the crank bearing went and it go so hot that it welded it self to the crank. BUT when i split the cases I found a bolt and beat up under the tranny. Any ideas?
