Stripped Thread
Somehow the lower radiator shroud bolt that goes into the tank is stripped and cannot get the stock bolt in. Any recommendations as the tank is aluminum.
Well you could tig it up but gas tanks are dodgy, I would get some steel putty from Loctite or similar, it can be filed, drilled retapped atc
helicoil ? wont happen again.
luckily it's not plastic tank
