Fuel screw adj.
So just noticed my 09 has an aftermarket fuel screw I can play around with..
How can I tell when i reset it to all the way in does it just stop like the suspension clickers or get snug or what..
And how many turns out is safe to go? Gunna play around with it maybe get it a little bit better.. Also if u have any tips on throttle response let me know, thanks
It will bottom out. Just turn it lightly and don't force it. No more than three turns out.
Edited by Joshx221
stat at two turns out then have the bike idleing turns the screw in untill you hear the motor skip a beat or stall mark this value down. Then go back to two turns out and turn the screw out this time with it idleing untill is skips studers or stalls. mark down this turn value. Then your proper position will be in the middle of the two values you wrote down. if it is less then one turn out then i believe you need to go bigger on pilot. If it is more then three then you need to go smaller on pilot
I might be wrong with when to go to a bigger or smaller pilot based on the number of turns if u go to the stickys there is write ups on jetting and i believe thats where i first read about how to set urair fuel screw
I didn't reset it because I don't feel confident because it was pretty hard to turn cus some dirt interfering I turned it out less than a 1/4 turn and that made a HUGE difference bike feels so much better especially on downhills i have more throttle.. Never payed much attention to setting stuff with the carb but I will now! The slightest change and it's such an improvement
Edited by Jrc579
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
