Honda CT 125 cam timing
According to the Clymer Manual, there should be an "O" mark on the cam sprocket, just above one of the cam bolt holes. With the crank at the "T" mark, the "O" should be at the 12 o'clock position, in line with the V-notch in the head. Quite possibly, the cam sprocket is mounted inside out, with the "O" mark facing in (?)
