Can you run a 14t sprocket and run a case saver on a yz125?
The 125 i just bought doesn't have a case saver and I have a 14t sprocket to put on when my engine comes back from gorr but I was wondering if I can run a case saver with the larger sprocket. Thanks
Yes you can. You can grind down the stock one until it clears the chain. I'm also sure there are 14T aftermarket ones somewhere as well.
No modifications needed. The stock case saver fits just fine with the 14T sprocket
14T and PD o-ring/x-ring chains rub on the stock case saver for me. I had to remove material for it to clear.
I always run regular chains on my small bores. Might explain why.
Oh ya then you'd should clear fine
