Aprilia Tuono mirrors
Will they fit on the 13 DRZSM? Do I need any extra bolts or anything? They have some for 30 bucks on Ebay. Anybody had good experience with the knock offs or should I get the OEM Aprilia's?
Thank you guys.
Edited by jazzyfunkybluesy
As long as they're a 10mm thread they will fit. I cant remember the pitch but I believe it is common throughout the manufacturers. Be wary of the China knock-off mirrors though, I purchased some z1000 mirrors off ebay and the mirror on one was totally distorted and fish eyed, I would stick with oem from my experience.
Edited by vagrantidol
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
