Marzocchi shiver 48 shims stack...need help !
Hi guys...just a quick introduction of myself then the question...I'm Max from Rome, Italy, love enduro and I have this new Marzocchi shiver 48 absolutely too stiff for enduro. I think this fork it's really well made, a sort of Kayaba, but need help with the shims stack. I just change the main spring, original was 5.0 now is 4.6, and oil but it doesn't works. It's really hard to drive on the rocks..the front tyre just jumps on the side and my arms are really suffering. Now the problem it's that I have good skill in mechanic but nothing on hydraulic tuning so I need your help. You will see now the actual shims configuration and I would like to have some help from you guys. That's the configuration:
A : 11 2.45
B: 11 0.2
C: 11 0.2
D: 14 0.15
E: 17 0.1
F: 20 0.1
G: 20 0.1
H: 20 0.1
I: 12 0.15
then piston
L: 18 0.15
M: 16 0.15
N: 15 0.15
O: 11 0.20
P: 20 0.10
Q: 20 0.10
R: 20 0.10
S: 12 0.15
A: 32 0.30
then piston
B: 28 0.10
C: 12 0.10
D: 32 0.15
E: 32 0.15
F: 32 0.15
G: 14 0.1
H: 24 0.1
I: 22 0.1
L: 20 0.1
M: 18 0.1
N: 11 0.2
I don't know the top little spring rate but the diameter of the iron is 4.00 mm....I also attach a couple of pics to explain better the configuration.
so guys thanks for your help...
I dont like the stiff springs which zokki uses on the mid.
I would try to get a softer spring, I used the showa spring on zokki 45 forks. This one looks quite higher.
Anyway, the setup is strange as zokki always is.
It would be nice to know the float of the midvalve. Thats the amount which the shims can lift before they start to bend. You can either calculate or use a feeler gauge to measure it.
Does the 28mm faceshim on the basevalve cover the ports of the piston?
Throw the zokes away and get some KYB's...
the setup it's really strange...u right Vietze !!! The 28 shim doesn't covers exactly...I think for a faster start but not so expert to bet on !!! Please lemme know more about the float of the midvalve..are u referring to the top part of the piston or to the spring side ???
thanks for help...
so...any new idea ???? :p
bleh why would you do that for enduro use
Why wouldn't you? We did it with great results on a 11' GG 250 but it only had 45mm zokes stock.
no thanks, I love my 45mm zokes, once they are revalved
midvalve float:
its the spring side of the piston.
You have to assemble the piston and you will notice that the shimstack can move a certain distance. Thats the float.
Could you do a picture of the basevalve piston which shows the ports?
What diameter is the pistonrod?
Does the 18.15 rebound faceshim cover the ports?
Is there a bleedhole in the rebound piston? If yes, what size?
will measure and will post all details today............thanks a lot Vietze !!!!
ciao max
by the way can I measure the float as I disassemble the piston from the fork ??? I mean with a valve feeler gauge ???
Its better to have the valving assembly tightened with the nut to make the float measurement.
11 0.20
11 0.20
14 0.15
17 0.10
20 0.10
20 0.10
20 0.10
12 0.15
12 0.15
20 0.10
20 0.10
20 0.10
20 0.10
11 0.20
11 0.20
15 0.15
16 0.15
18 0.15
32 0.30 (check plate)
28 0.10
12 0.10
32 0.15
32 0.15
32 0.15
14 0.10
24 0.10
22 0.10
20 0.10
18 0.10
11 0.20
11 0.20
Actually looks like there's no float according the gauge even if there's a shim 20x0.15 before the big 20x0.10 shim that covers the face of the piston...maybe it deflects and looks like there's no gap. There's no bleeding hole in the piston and the diameter road is 12mm.
Attached a pics of the basevalve piston that shows the ports.
Sorry...I made a misunderstanding for the float...will remeasure and post later...Vietze can u make a draw of the float so I can measure it correctly ???
thanks... :rolleyes:
Edited by contemax
Just an idea. I reckon it's blowing through the stroke and smashing into the mid.
So on the compression valve, maybe try something a little more conventional.
That is a nasty mid. I'd be tempted to create some float and lose 2 of the 20 and 1 of the 11. It's like the 15, 18 and 16 are there just to take up space.
I think this is not real mid at all as zokki uses this design in all forks so far...
Thats why I want to know the float.
But I also think that its blowing through. The reasons are the two 12.15 bleedshims on both sides of the reb piston. The base has bleed, which is a good thing for the kind of riding Max does. But when the stack deflects more it hits a wall of damping...
The reb is also very "easy minded"...
Hard to get it right on the first revalve.
Many people like the calculate the float distance but since the zokki usually doenst use a collar it can get pretty difficult.
Here is a pic I found on the forum:
Just see what thickness of feeler gauge fits between the piston face and the faceshim.
I guess its around 1mm-1.5mm :-D
I have measured something :banghead: ...could it be 0.40 mm ???? Basically I have measured the gap beetwen the last shim 18x0.15 and the base where it lands !!! It is correct ???
P.S. Sorry guys to trouble you but actually looks like this is the only forum in which I can be helped....nothing here in italy and I'm really tired to spend 400 dollars everytime I get a new bike to tune the fork and also most of the time I'm not satisfied !!!!! And a lt of people like me.....
Doublecheck your measurement.
You can also insert the gauge between two 20.1 shims. You have to push the shims/spring down till it hits the bigger diameter of the valving holder.
Zucco Suspension is down there in the middle of Italy. He is also on the forum and one of the best tuners I know.
is the float A or B ??? If A there is no gap beetwen the shim and the face of the piston....B is 0.4
ok it should be A holding down the spring...I go to measure...will be back in a while....
  • Similar Content
    • By Chris Edwards
      Hey guys, I'm wondering what suspension settings you all are running front and rear?  I have a 2017 crf 250r I'm a 210lb newer rider, my settings are currently set at,
      rear suspension low speed  at 12 clicks
      rear suspension high speed 2 turns
       rebound is 12 clicks.
      Left front fork inner chamber 150psi, outer  chamber 10psi, balance pressure 150psi
      Right front fork compression position 7 clicks, rebound 29 clicks
      Sag is 4"
      Thanks guys
    • By Stillwell Performance
      One of the most common calls we get here at the shop is “how do you recommend I go about tuning my suspension?” Good question! The second most common call is “I started turning clickers on the front/back/bottom/top etc. and now I don’t know what I did, help!” The amount of improvement you can gain from proper suspension setup is significant, if you go about it in the right way.
      Look at it this way: if you are 6ft. tall and get in your truck after your 5 ft. 3in. wife just drove it, the first thing you are going to do is adjust the seat/steering wheel, etc. for your size. The same thing goes for your bike’s suspension-last week we had (3) 2010 bikes in the shop for revalves at the same time. Identical models, one guy was a 150lbs. pro racing MX, the next guy was a “B” level GNCC racer and weighed 220, and the third guy was a 180lbs. trail rider. Same bike, three totally different setups!
      So with that in mind, here is where to start:
      • Grab your owners manual, a computer, clipboard and a scale. You cannot effectively start tuning until you determine if the correct springs (fork and shock) are on the bike for your weight. Put down the double cheeseburger, hop on the scale, and get your weight in street clothes. Add in for your gear, which typically runs between 20-30lbs. You can easily check recommended spring rates by visiting under their spring rate calculator. Look in your manual (or ask your tuner) and see what rates are on the bike.
      • If you need to change spring rates-do it first. Trust me on this, trying to tune suspension with the wrong rates is not only frustrating, but you will be short changing yourself on the results. On most bikes the shock spring is easily changed, fork springs can be a bit more difficult-get qualified help if you need it.
      • Even if you are familiar with what “clickers” are, take a moment and read your manual. Determine what style of forks you have (closed cartridge or open cartridge), where the compression and rebound clickers are, and check to see if your shock has both a high speed and low speed compression adjustment.
      • Grab the right tools to adjust, load up and go find a typical piece of terrain to test on. By typical I mean your MX track, hare scrambles course or favorite singletrack. You don’t need to ride a 30 mile loop in order to adjust your bike, rather focus on finding a section of track/trail that has all the different types of jumps/bumps/whoops you encounter.
      • OK here is where I will preach a bit-everybody has a buddy or two that claims to “know suspension” and setup. This is YOUR bike, and unless you plan on dragging him around on the back of the seat the end result of your tuning should be focused on what feels good to YOU. Trust the feedback the bike gives you…..
      • SET YOUR RIDER SAG!!!!!!! This is critical to tuning properly. Again, look in your manual or ask your tuning dude.
      • If you do not have an idea of where to set your clickers, put them in the middle of their adjustment range. This is your baseline setting.
      • Gear up and get warmed up. It is important to be loosened up on the bike BEFORE you start tuning, or you run the chance of mis-diagnosing how the bike is feeling (I never start testing until I have at least 15-20 minutes of warmup time on the bike-I always ride stiff initially and sometimes do not get into a groove until then). Some guys can just jump on and pin the damn thing right from the truck. You know who you are, Wattsy……
      • Remember, this is a tuning session not the MXoN. Use you head and ride at a pace UNDER you max speed-there will be plenty of time to “fang it” once you have zeroed in on some good settings.
      • OK-ride and get a good feel for the bike with the clickers in the middle of their range. Now it’s time to really find out what “too soft” and “too hard” means.
      • Take your clickers and turn them all the way out, full soft. Go ride the bike, but take it easy-it will feel ALOT different. Then come back in and turn everything all the way stiff-go ride again, being careful as this will feel totally different again. For guys that have tuned a bit, these two steps might seem pretty basic, but you will be amazed at the difference in how the bike feels. This is especially helpful for guys who are just starting out.
      • Set everything back to baseline. FROM THIS POINT ON YOU WILL ONLY MAKE ONE ADJUSTMENT AT A TIME!!!!!!
      • So now you will want to determine your tuning range. The tuning range is what settings you will use to adjust for different conditions. For example, If you are an MX racer as well as an occasional singletrack rider you will want to use different settings for those conditions.
      • Fork compression is a good place to start. Ride your test section at baseline, then go about 3 clicks softer. The question to ask yourself after each adjustment is: Does it feel BETTER, WORSE, or THE SAME????
      • There are no right and wrong answers, only what you feel. So let's assume that the 3 clicks softer felt better-go 3 more clicks softer each time until it does not feel as good. You have just found the soft end of your fork compression tuning range. Now return to baseline and do the same thing, only this time go stiffer. After you have found the best compression setting, work on rebound. Remember, one adjustment at a time ONLY or you can become confused!!! Do the same testing with your shock. Once you have both comp and rebound individually adjusted, you can fine tune them to work together-just make one adjustment at a time!
      • As a final test, when you have what you would consider your best setup, write it down, then go back and compare that to your initial baseline, riding both setups back to back. Might surprise you…….
      I could go into some advanced tuning topics about the interrelation of compression/rebound, high and low speed comp, tuning for extremes, etc. but we will save that for another newsletter. Take your time, tune by how your bike feels to you and have fun. You will be surprised by how much better you will ride with well adjusted suspension.
      You can learn more at
      KEEP IT PINNED!!!!
      Alan Stillwell
    • By Jo_nathan
      Selling the showa A kit off of my yz250. It comes with a set of like new x trig adjustable triple clamps. Have 4 rides on rebuild and overall in great shape. Few dings, no dents or leaks. Setup for a 165lb a rider. Work absolutely awesome! I got hurt and cant ride for a year so I'm selling off some of my parts.
    • By Kim Franz
      lookin to upgrade my suspension on my 06 cr250, curious whats possible with some work.
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
