Getting float bowl gasket to seal
Are these gaskets held in by glue or silicone from factory?
ive taken the carb bowl off heaps before and never had problems with it leaking but when it finally tore I replaced it with an as new second hand one as a new one will take a while to arrive but theres no way it will seal with the scews done up tight. The float valve doesnt leak when closed
Any ideas? mabye a brand new one will do the trick but i think the gas is just finding its way under the u shaped indent
No glue is necessary, most would dissolve anyway. Are you installing the bowl with the carb on the work bench or while the carb is on the bike?
