Mid rev bogging 08 yz250f
I recently installed an Athena 290cc kit on my 08 yz250f as well as hot cams, it seems to pull good at the bottom and the top of the rev range but at mid revs it sort of sputters (loses power for a split second then comes back) it does this a few times until I hit high revs then it seems to smooth back out.
I am running a 178s Main jet, 48 Pilot jet, #40 leak jet, and my air fuel screw about 1 3/4 turns out, and the red JD needle with the clip 5th from the top as well as the fat oring from the JD kit. I am still fairly new to jetting so was wondering if anyone had any clue on how to even start to fix this problem.
Thank you for any help you can offer
  • Similar Content
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
    • By husky159
      I have the following to sell...
      215 grip studs with the insert tool. Only 2 rides on them. $70 + shipping
      Stock 17’ 300xc silencer with enduro engineering spark arrestor. (Small dent, a few scratches) $70+shipping
      hyde skid plate for 17’ 300xc in good shape just your normal scratches. $60+shipping
      mikuni 40mm carb with 2-3 rides on it. Includes throttle cable/ tube. Also extra jets and such. $175+shipping
      feel free to ask for more photos
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
