Oil Leak
I have a 2006 rmz250. I went to change the oil on it and the drain plug was cross threaded. We drilled the hole and put a HeliCoil in it. Then i bought a new drain plug and gasket. I filled it with 10w-30 and it still leaks when the oil is hot and cold. What other solutions are there other than gasket maker?
Wenever you drilled into it did you drill into the threads? Idk why its leaking.. Unless you didn't put an O-ring back on it?
you have to drill the threads to put the HeliCoil in and I didn't put an oring in because when I looked at the diagram it didn't show it having one.
Try throwing an O ring on it and see if that solves the problem.
ill try it
ill try it
let me know what happens
