Clutch cable gizmo
I need the little sleeve gizmo that INCREASES the size of the fitting where the clutch cable attaches to the lever.
My local stealer said I need to purchase a new cable. Any suggestions ?
Got a buddy with a lathe?
I'd just make one.
Use anything from the body of a plastic ball point pen (soft'ish plastic one) to a small section of PVC tube. I'd just grab anything that is plastic and a similar same size then cut a replacement - if it doesn't last just try something else.
Go to a big box hardware store... over to the plumbing section....get a foot of plastic line.... the water line stuff should work just fine.. cut off 3/8 of an inch.. throw away the rest.. slit the small piece, install go ride... done.. under $1.00
Yeah .. The Local Stealer ... For sure
Go to a big box hardware store... over to the plumbing section....get a foot of plastic line.... the water line stull should work just fine.. cut off 3/8 of an inch.. throw away the rest.. slit the small piece, install go ride... done.. under $1.00
"Easy As"....damn killed yet another thread... :worthy:
Maybe don't throw away the unused line , cut it into similar pieces and sell em on fleabay..... :eek::smirk:
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
