G'day could any one please tell me the spigot size that goes in to the motor on the cam chain tenshioner I just bought a second hand one from me local reckers but I think it's the wrong one I think the spigot is to big I don't want to pull it apart to find out if it is the wrong one any help would be appreciated thanx
The cam chain tensioner hole in the head is 26.70mm
Thank you sir il measure it up when I get home
I measured up the new part its 26.6 mm dose 42 mm bolt centers sound right thanx for the help
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
