Kx65 Rebuild parts help
Where is the best place to get a good price on a rebuild kit for a kx65? Top end and bottom end and maybe a new cylinder. As of now I know it needs a top end. Also what is the best brand top and bottom end to get without breaking the bank? Its a 2002 Kx65. Thanks
shop ebay
namura pistons are great..i dont care for wisco anything
hot rods crank...unless you want to spend extra for a OEM crank...they good too... you should be able to get some pretty good deals for a 2002....cranks after 05 wont work in the 02...
Use a hot rods crank. I found a complete bottom end kit from hot rods when I did a 65 last summer. I have had good luck with pro-x and namura cast pistons. I think it is the wrong application for a wiseco forged piston, I have a kx65 in the garage with cold sieze marks on the wiseco piston. I think you will have to go oem for a jug, I use ronayers.com for my oem parts.
Look at Partzilla.com. The place is by far the cheapest for new OEM. Many times cheaper than aftermarket items. I just bought Yamaha top end gasket kit, and Piston kit with roller bearing. Total price for 2 full kits $120.
Did my sons 02' with pro x top end cometic gaskets all from Motosport.com
Replate the cylinder if it needs it, otherwise, new piston and rings.
For the bottom end, purchase Suzuki RM 65 rod, washers, bearings and big end pin from a place like powersportspro.com and have the crank rebuild by rb-designs.com
I'm doing thiswhat right now. good luck
Replate the cylinder if it needs it, otherwise, new piston and rings. I used US Chrome for an overbore and plate.
