2013 CRF 450 oil amount?
Pull gearcase oil level bolt and fill until it overflows out of that hole with the bike in a straight up and down orientation. Fill engine oil until it shows correct level on dipstick. Oil amount will change with oil change or oil/filter change.
Per the Service Manual:
Crankcase on port side~
.66qt (US) with Filter change
.61qt (US) after oil drain only
Crankcase on Starboard side (transmission)~
.68qt (US)
I you had a CRF before you know which drain plug is for the trans and which is for the engine oil. If this is your first one it an be confusing because the drains are on the opposite side from where you fill them.
I find the manual specs a little out. I run 600ml in motor side and 700mL In the clutch... Run bike 3 mins and cool down for 3 mins then check with bike on level ground the whole time
