drz 434 sm stock pipe non fcr jetting?
Hello to all ,I am new on here and need info on tuning my drz.
specs
2007 Suzuki DRZ 400 SM
stock cams (sm)
stock pipe/ cap
stock mikuni carb (non FCR)
mods : hot rods stock stroke lower end
all new bearings/cosmic gaskets
CW 434 new bb kit 434 cc vertex piston (12.5 to 1 comp)
k&n air filt
max cycle royal purp oil
small oil cooler on filter cap
40 mm thick radiators
ebc clutch / pads
i am at ~ 1,200 ft above sea
i ordered a jet kit for a drz 434 from "6 sigma racing"
stage 1 to 3
it came with main jet 146,150,155
pilot jet 27.5
2 needle shims
1nylon spacer
1 slide drill #59( tiny) for drilling the vac port
and plug drill bit/rem screw
& i have the stock jets ?
the bike has not been run yet since rebuild
what is a safe jetting to start with i dont want to roast my new vertex :0
any gen help would be great 🙂 thankx in advance
yes i can do 3x3 air mod & no pipe cap if i need to
You cannot cook a 4S. Worse case is the bike runs poor (flat/dry/bogs)
Your kit is just a repackaged Dyno jet one. All the jets are unique to dynojet nd not interchangable with stock style ones.
Smart money is to return that kit, buy a James Dean one, follow the included instructions EXACTLY. Also get a Kientech fuel screw.
You will be a little rich with a stock, unchanged carb and stock muffler with your big bore.. Slowly opening the airbox to the max of 3X3 may enable adjustment without a jet kit.
Stock needle is not adjustable.
TT store sells the screw, Kientech also sells direct
Jame Dean kit comes with two pilot,s, three or fvie maines, allen bolts for the float bowl, two needles. Though you might want to check his website to confirm.
above
