DRZ400S FCR Problems
So I bought a used E-Model FCR from another TT member and finally got around to installing it the other day. I turned the petcock to prime to fill the carb and gas started coming out of the float bowl seal. I cleaned up for the night and decided too look at again the next day. I come back and the leak had completely stopped. The bike currently starts with max choke and when it get warm and I take the choke off it idle like crap and stalls. If I give it throttle it bogs really hard and stalls unless i give it more then almost full throttle.
My bike setup 01 DRZ400S
e-model cams
Yoshimura debaffled RS3 slip-on
UNI air filter
deCaliforniacation
3x3(closer to 3x4) Mod
Here is the carb setup..
Freshly Cleaned carb
Eddie mod done
TPS Removed
EMN Needle in the 3rd clip position from the top
Coast Enricher removed
Pilot air jet removed
160 main jet
200 main air jet
45 pilot jet
R&D Flex jet 2 turns out
Sudco Carb Adapter
Edited by WonTian
FCR carb from a DRZ400E, you definitely need a pilot air jet. With the CE removed and the side nipple sealed, you need a 100 pilot air jet. The other jetting looks OK.
You may have other problems but hard to tell until you fix the air jet. Verify the slide plate is not up side down. As you open the throttle, light appears under the center not the sides.
Thanks for the reply. I'll try to get a hold of one tomorrow when the shops are open.
The slide plate is kind of arrow shaped. I put the plate in pointing up. Is that correct?
Yes. The "arrow point" points up. The rubber seal between the slide plate and the roller slide needs to be in good condition also.
It seemed fine when I had it out but I'll double check since the carb has to come out to fit the air jet
Yes...install a pilot air jet for sure........Also could be Pilot jet clogged or slide plate issue...
Are you running it on prime?
Did the previous owner give you a plausible reason for selling it.?..The carb may have an underlying issue...
I'll double check the slide when I have the carb out.
It's running on "On"
I think he was selling because he bought a 41mm carb for his big bore
Edited by WonTian
I pulled the carb and snapped some pics
Here is the AP video
All good except the AP looks late and excessively long. I have never really understood the wire mod to the pump. Can't advise you much on that. I would like to see it earlier and shorter by limiting the duration with pump stroke. But it may not be a problem at all.
So I popped the 50(60?) PAJ back in just for a trial run. I screwed the mixture screw all the way in and backed the idle out and the bike now idles and runs. It smells kind of lean and pops a little bit on decel but when I richen the mixture it drops the idle. So I'm leaving it screwed all the way in at the moment and I have a 100 PAJ on the way. But the bike is now rideable
How do I fix the issues with the AP?
Edited by WonTian
i would also like to know how do you shorten squirting time?
