2013 350 excf dead
Was riding my bike and pulled it in my garage and it just died like it was hit by lightning. Now i have no response at all when turning ignition or start switch. wont kick, nothing..just dead.. Any ideas?
Start simple, check for blown fuses - there is one that controls the start circuit. Doubt it would be bad but you can also throw a multimeter on the battery and make sure the volts are correct, the FI bikes act strange when the batteries have issues.
Try disconnecting the key switch and putting some wire in the holes so it acts as if its on. Or try this, put the key in the switch and turn it in the on position. (Nothing will happen right?) Then slowly turn the key backwards to see if the power comes back on. That happened to my 13 350. I replaced the key switch assembly.
Friend had something similar ended up being starter clutch
Try the kick starter with the spark plug out to check for a good spark.
