Suzuki Lt 50 steering stiff
So just picked another lt 50 and the steering is really stiff, especially at full lock to the right. It almost doesn't want to go back left. Suggestions please.
Check the steering stem bushing, It sounds like it may be rusted. You can take it off and check it and then put some grease on it and also make sure that someone didn't tighten the steering stem bolt to tight. if that is not it then check your spindles. Sometimes they will tighten up or will get rusting. Good luck
