MR250
Rebuilt the top end with a bore and new piston etc. bike runs good except starts missing around mid and then to being wound out. New points, tried different coils but it will not run with a new replacement coil from re-mx. re-did bike wiring but not from the stator out wire> I did not check the off switch but the missing is pretty consistent above the same rpm in any gear. set the point gap with an ohm meter.
any ideas.
