2014 KTM SXF stacks
Hey,
does anyone have the stock stacks of the bikes?
I'm searching for the 350 SXF stacks!
thanks!
Not quite stack's related but: Flo, could you clean up your Inbox?
Off top of my head
5x24.1
3x22.1
3x20.1
3x18.1
3x16.1
Mv
3x20.1
2x18.1
2x16.1
14.1
2x10.2
.35 float
3x20.d
11.1
16.1
14.1
12.1
10.2
Il post shock stack later
how daoe that base valve work for you guys?
is it worth a try in the older models?
I use that base with 14mm clamp, this midvalve with 0.3mm float and the stock reb for a fast 83 kg rider and he likes it a lot!
I used the same base with 14mm clamp and a softer MV (but also 0.3 float) for a 70 kg rider and he also is very satisfied.
Edited by Vietze
