06 YZ250 lower fork assembly removal?
Anyone ever remove the lower assembly that the fork tube enters? I noticed that my left fork tube has slop/play entering in the assembly but I've never taken one apart before.
After disassembling and checking over and over I believe I found what happened. The fork on the left side basically started to unthread itself from the lower fork mounting assembly. I'm not sure if the tuner loosened this up during the fork service or if basically it started unthreading itself? I probably should take it all apart and loctite it back on but I'm not ready to loose all my fluid just yet since it's pretty new. So I'm going to clamp the tube and tighten the bottom on the tube has good as I can get it for now.
