CRF230F Engine Vibration
I just picked up a very clean CRF2 and am shocked to find the engine very buzzy requiring almost immediate upshifting. I couldn't even immagine what it would be like to run down a road at even 1/3 throttle. Is this engine known to be buzzy or do i need to do something. My son's CRF150f is very smooth. It is an 06 with the different motor but still
Loose engine mounts is the first thing that comes to mind.
But I recommend to check every nut, bolt and screw on entire bike, front to rear, top to bottom.
Also recommend to use blue lock tight where required/stated in factory shop manual while using a torque wrench on everything that requires using one.
Is the heat shroud on the header pipe tight? I could see that being a real buzzer.
Grogg
Edited by Grogg
