Hour Meter Troubleshooting
Hey,
I am having trouble with my Works Connection hour meter. I have it mounted on my 2012 Yamaha YZ 250f and it has been perfect for the last 60 or so hours. I realized the other day that the display was not showing my hours, and it also fails to display my tach when running.
I took it off and then rewired it on to the spark plug wire, yet it still won't work... Not sure if it simpy quit and needs to be replaced or if there is a quick fix. So any ideas?
Thanks in advance!
Thanks to both of you. Swap, I had it mounted using the mounting kit for the bolt of the tank which seems pretty solid and away from vibration but, I might try different mounting tactics as well. Thanks again.
