07 450 SXF oil pressure issues
With the valve cover off, cranking the engine over I'm not building enough oil pressure to get oil to squirt out of the jet onto the cam lobes. I just replaced the pressure pump and spring and it made no difference. So my questions are while cranking (not running) it should build enough oil pressure to squirt oil onto the lobes right? And can worn suction pumps cause this lack of oil pressure? Just want to know before I spend the $ on all new oil pressure related parts. Thanks.
