cylinder head bolts leaking oil
on my 03 rm125 it seems like all the bolts are leaking oil where the nut goes on them. any idea what to do to stop this?
Ok found my answer in the title... this is a sign some compression is leaking through the head gasket. If they are O rings its not very expensive.
X2. Clean the PV and check out the top end while you're at it 👍
after further inspection, I found the substance to be watery, which I now have to assume is coolant. would this also be the head gasket?
Most likely it is the head gasket (oring), but can also be damaged cylinder head.
probably a warped head, get your head checked and replace the head gasket
try tightening the nuts, if it doesnt stop, new gaskets (at least) are in order
