DS 90 Idles but stalls with any throttle
2004 DS 90 with good compression and a new carb and air filter. It starts easy and idles well but it will immediately stall with even easy throttle application. Sometimes it will run okay when it is cold but when it gets hot the stalling generally ends the riding session. If you can get past the immediate stalling upon throttle application the engine will run okay in the mid-range and high end. Gas seems to flow well through the drain on the bottom of the carb. I am stumped.
