Tachometer?
hey i was wondering if anyone has put any other tach on the drz that is not the TTO or the vapor?
im not a terrible big fan of the TTO digitachs, and i want something more analog, but i dont think i need the whole vapor dash
When I was working on the area above the headlight to put in a 12v power supply, I found a wire pair with 5v on it. I would be pretty sure that is a tacho signal set. If so ANY aftermarket tach signal tacho may fit.
If you want a simple tacho, try acewell stuff. I used some of theirs for my roadracing bikes and they make a small one that uses inductor wrap around the plug wire as well as others that use tach signal. I found them VERY reliable and accurate. I will put on on the SM when my girlfriend decides if she wants to keep the SM as her roadie bike.
The DRZ ignites on every revolution, so you have to get a tach that can compensate for that.
Sorry no factory wires. There are some threads using analog gauges though.
The wire you found is likely the factory trip meter reset.
