ibeat questions
does ibeat actually tune/remap your ecu or is it just a fault and adjustment program ? I have ecu specialist in my area who remaps ecu but its nearly $500 bucks ! they say it improves hp blah blah would a power commander do the same thing ?( I got a jd tuner on the from usa now)
I beat adjust the EFI and TPS settings, read codes and displays motor/system info. This is a great tool to have if your dealer is not close by. Your tuner box does a bit more tuning however your can get near the same tune with Ibeat and you can do other bikes too. Power Commander does the same thing as the JD tuner just with more adjustments and needs a PC. Power Commander will be $500 when all is done using auto tune option.
Edited by weantright
