Ktm leaking tranny oil
Hey guys, I just found a little oil leak coming down from my front sprocket and I think its from a seal from behind??
-paul
That is a good guess, there is an o ring and a shaft seal ring in there and sometimes you have to replace the spacer as well....depends how worn it is...easy fix
Edited by Lmiinch
I replaced mine last year and went with Synergy. Also make sure you're using an OEM CS sprocket or at least one that mic's to the same specs as the OEM. The thickness of the CS is detrimental to the effectiveness of the seal. If it's too thin, then you will be constantly leaking as long as you're using that sprocket.
It's an easy fix, lay the bike on the ground on the throttle side and go to town. Make sure the area is nice and clean before you take the sprocket off and end up with shitty gritty dirt inside where you don't want it causing more problems later on.
