Kickstart problem need help
I have a 2002 kx250 that I recently had to take the right engine cover off to change the water pump seals as I put everything back i noticed that the kickstart won't go down all the way it stops about half way but wont go down any lower. Anyone know what it could be I'm realy stuck. Thanks
The same thing happened when I took a part my crf450r. You'll need to take the cover off and inspect everything to make sure something didn't become misaligned or fell a part while the cover was off. Some things are kept from moving laterally by the cover (such as the shift lever) that can be moved out of place by operating them with the cover off.
Drain the coolant and oil into clean containers and reuse it.
