Shim inventory suggestions
Thought I would take a shot at this. Anyone have a list of shims that would be a good inventory for a small suspension shop? Something that would be able to cover reshim work for a large portion of the more common dirtbikes? I understand it might be a very long list but if I order 500-600 shims what would be my best choices?
Thanks for your thoughts.
It does not matter what you buy because you will miss exactly what you need for a certain job... =)
Not any more...... You will never be short a shim again...
http://www.etsy.com/...set-3mm-to-16mm
Edited by MRW
Yes, works perfect 🙂 I think every one has a million 30mm face shims to play with...
I edited my first comment and updated my original link with a new one that shows the actual metric sizes.
Looks interesting, I'm curious if it would be able modify a shim in a pinch to make it a different size.
Edited by MRW
