2 stroke silencer help?!
I have an '05 tm125 2 stroke ( not that it matters...) and since I bought it the silencer was damaged (I was fully aware of it being damaged). i realised it would have to be replaced soon enough or have a DIY repair job done.
In the beginning there was 2 problems.... 1. It had no baffle, just some old ,dirty packing that lined the inside and 2. it was leaking at the back (loose rivets) .
I cracked it open and replaced the rivets , sealed it up and left the old packing in as it was sitting snugly (so it seemed) and doing its job rather well for its state.
a few small rides later ,I was cruisng along when I had a sudden loss of power. It turned out to be the packing. it had been pulled off the inner walls of the silencer and pushed out the opening of the exhaust. I pulled out the remaining packing and continued on ( I had no choice really).the Bike hasnt been ridden since I'm doing some maintenance.
My question is will it be ok (by ok i mean not damage it, minor power loss is acceptable when using it but no lasting damage/powerloss) to run the bike with what basically is an empty can on the back for a few more rides? other than the annoying whistle it makes aswell as the now twice as loud bellow power seems ...great , its running the best it ever has:)
I will go back for 2nd DIY repair job in a few weeks and if all else fails i will........purchase a new silencer :(
Put new packing in for under 10$ or use insulation, works the same!
Ride it until you can fix it. Once you open it post some pics and I'll give you some tips.
&%$#@! sorry, its already fixed 🙂
for the baffle I used a steel pipe off some stand that fitted nicely over the remaining stump that is the old baffle. since my lack of power tools , in stead of holes I cut many many slits with a hack saw all around the pipe and to hold the new baffle on I used metal epoxy.
i wrapped the fibre glass around the pipe then cut off the excess at the top with a stanley blade. I slowly fed the fibreglass wrAPPEd baffle in to the can, when i had most of it in I applied epoxy and heatproof silicone to the inside of the end of the can to securely seal and hold hte pipe and baffle , I then re-riveted the silencer at he back (Italians havent invented bolts yet) , along with the epoxy it was a nice strong hold. Once tested it it sounded quieter but not exactly better..... but the whole reason i was doing this is to improve performance and quieten it down which I got in the end. 🙂
yeah man but the my problem was that if i do repack it there is no baffle to hold the packing in place so the same thing that happened before will happen.. and plus its a riveted exhaust and the original rivet holes are damaged so its a b...tch to open up and then seal up tightly again. but never mind I made a homemade baffle and reconstructed the silencer 🙂
