Oil change - which gaskets/washers need replacement?
Hey guys
I just picked up a 2009 rmz 250 with 87 hours. It has been well maintained and I've gone over the manual for what needs to be done. Ill be doing the oil and filter in three hours and have a few questions (tried searching but no specific answer)
1. Which washers/gaskets need to be changed during oil/filter. Which can be reused?
2. Is there a second metal screen filter that needs cleaning that is harder to access (i remember reading this once) or just the one on the right side by the frame?
Theres a screen tube/strainer behind a plug on the left side of the motor its 12 or 14mm its kinda tucked behind the lower frame rail for the engine. Its almost inline with the drain plug
