gas gas 450 fse fuel problem
the bike just cut out and wouldnt start after a 2 hour ride, has loads of compression, a good spark ands still makes the fuel injection sound, when tryin electric start it just makes a clicking sound tho, tryed kicking and bumping but wont start up, just wondering if anyone has any idea to what cud be broken?
yeah and ive kicked it countless times still compression aswell, charged the battery to try electric start bt thats just makein a clickin sound and then i took the plug out and pored petrol in to try and get to fire but still nothing, dont have a clue what it could be tho mate
Not a jetting issue. You have some sort of electrical failure. Check the cables at the battery and at the chassis ground and the starter relay. Confirm you have at least 12.8 volts. Then test with the E button pressed, you should still have 12.8 or 12.6 .
Checked the 30A fuse in the airbox located on the start solenoid? Could also be start solenoid. Check for good contact of all wires/connectors into the start solenoid.
