bike getting wrong air to fuel mixture due to intake being shortened
I had to use ther air box so I re-ran the intake with a shorter tube what would be a good intake the fix the mixture problem the carb air fuel mixture is tuned at its best but the air cleaner is too free flowing. I checked for a vacuum leak but nothing leaks. I have a 2000 honda xr100r it rj ms with a lot more torque when the load to gear and throttle ratio is right but at some points there's a dead spot in the rev because it runs lean.
