Earth Ground wire on CDI
I have a green wire coming from my CDI which has been cut. It works and runs fine but Im assuming it was put there fro a reason by Honda. Its not part of the connector block. It appears to come out of the housing on its own. Should I connect it to the frame?
2003 xr250 with a 400 motor. the cdi is probably off the 400 I would imagine.
The green wire from the cdi is supposed to be tied in with the green frame ground wire in the harness. Same on the 250.
