Help with scooter!
I have a friend that has a lance vintage 150 scooter that is acting really wierd. While its running if you unplug the voltage reg/rec it will die? And when I measure voltage at battery while running I get 9.5v at idle and at higher toms I only get 6! I have no idea what's. the problem cause I thought it should run without reg/rec
