Replacement clutch release?
Greetings. I have a pair of '72 TS185s. On one, the clutch release is worn quite out, with so much linear slop that no matter how the clutch is adjusted, there is no more than 1/8" depression of the pushrod.
The other is crushed on the back side of the magneto cover, probably by the same object that took a big chunk out of the magneto cover.
I have Googled extensively and have not found an aftermarket replacement for the clutch release assembly. It is not likely to be a generic part as it's assymetrical. Has anyone found a source for aftermarket parts, or original parts? Everywhere I have looked says "Discontinued".
Thanks in advance!
