bleeding rear brakes
so im trying to bleed my rear brakes and i am back bleeding and for some reason when i push the brake lever down it doesnt work still (it goes down with no resistance resembling there is air or something inside.. i have made sure there is no bubbles and have checked twice. I dont know whats going wrong.
what do i do?
back bleed the breaks with a surigine making sure you are not adding any air into the line, also the the rear brake off the bike (while sealed) and till it every which way then leave it with the reservoir at the highest point to let the little air bubbles float to the top.
I had the same problem with my back brakes, I eventually gave up trying to bleed them and gave it to a local mechanic who said there was an air bubble stuck.
Edited by Mo Ameen
