Check that spring!
If you own a Kx 250 years 05-07, take 5-10 minutes and do yourself a favor and check the main powervalve spring on R/H side of the cylinder. Pull the pipe, remove the 4 bolts that hold the cover on, and if it looks like this, replace it. (You can see the truth mark on the side where it should have been). Once again this $4.54 spring had me going in circles. Basically, if your bike feels like it is lacking bottom or flat in the mid, check this. Even if its not, replace it. This should be in the troubleshooting guide in the back of your service manual! (which I know everyone here has🤣 ) This is my 3rd time replacing this spring with one time being preventative with a top-end. The Kawasaki shop down here says they used to keep this springs in stock up until Kawi axed the KX250. SO.... CHECK THAT SPRING! and ride on :ride:
Edited by mxeightyeight
