Rear shock swap? cr250
I just picked up an 03 cr250 with a rear shock that will not move. My question is what shocks off of newer Honda's could I use? lokking for something the same length and not wanting to modify anything. any thoughts would be nice!
not sure the difference in length, but I have a brand new 08 CRF450 shock if interested. I think you can just change the clevis and put your CR's on it and it bolts right up. Not 100 percent on that though.
The 02-04 shock should bolt right up.
The 05-08 CR/CRF would require changing the clevis as it's 1" longer than the 02-04 models. Another option would be to change the rear linkage & shock with the 05-08.
You sure its the shock? Have you ck'ed the linkage, swing arm bearings?
